Show us your Dynolicious!
evoman
Post by evoman »
Ok all you iFags with your iPhones, download Dynolicious, calibrate it, chuck it into your car dock, find a safe location and record how quickly your car can reach the speed limit.
For starters, I'll post up my appalling performance :lol:
As you can see it fell out of the dock a bit after the change into second gear, but you get the idea. Test was completed in 38 degree heat back in January with a full tank of fuel and one passenger, but I don't think I can get too much quicker out of poor the old girl in stock form anyway :-(
For those who are having trouble reading it,
- Yellow line shows KW's atw. 75kw recorded :-(
- Blue line shows G's. Max .55 achieved.
- Red line shows speed and acceleration.
0-100 in 8.37s :-(
0-50 in 3.00s
Show us yours!
spency
Re: Show us your Dynolicious!
Post by spency »
i got a bit excited and went 45km/h over the limit :s road was wet so i had a bit of wheel spin high up.
0-100 = 7.96 sec (had to wait for lights to go green)
peak kW = 123kW
That is f**ken cool
True, but pictorial evidence of breaking the law right there ^ :|
FTO84
Post by FTO84 »
^^ Only when he said it was on a public road. :facepalm:
spency wrote:Image
peak kW = 123kW
Dont you mean 9.01 secs????
spency
Post by spency »
Notice the two full seconds where nothing was happening?
No, I notice half a second but not 2
FTO_GPvR
Post by FTO_GPvR »
With the blue line how it shows G's, does that stand for G-Force?
brad_gpx
Post by brad_gpx »
I8A4RE wrote:No, I notice half a second but not 2
Each box on the graph represents 1 second
wow really??? :facepalm:
AT the 8 second mark he is STILL accelarting. It not till around 8.5 that there is no longer acceleration and the curve flatens off.
One question for you all, have you got a true weight of your cars to enter into the setup?
If not the it's not a true test also if you have it set up right it starts timing and all that as soon as you hit the power so there would be no down time.
evoman
Post by evoman »
Yeah, I would suggest you do a rerun spency because you should not have the delay like that. Recording should only start as soon as the car moves. Also need to make sure you calibrate it on a flat surface in similar temperature conditions to the run as the accelerometer is temp sensitive. iPhone also needs to be standing upright with it's back to the front and any movement will throw out power and g force readings so the dock needs to be secure.
Aza is also right about the weight. Unless you have exact weight of the car (+ people, fuel,wheels, stereo, luggage etc) the power readings will be out. Luckily we can leave the drivetrain loss fields blank to get an ATW figure.
Aza, you have got to give yours a run.
$15.99 ?!?! I THINK NOT!
iPhone?!?! I THINK NOT!
evoman wrote: Aza, you have got to give yours a run.
I know :lol: the car has only come out once for a drive in the last week and a half since I got it back from the work shop.
will try it out tomorrow or sunday :D
I will take it down to the track and give it a test :twisted: ;)
Supplanter wrote:iPhone?!?! I THINK NOT!
This ^ :lol:
this is just becouse that pic is just wrong Ben :lol:
You dickhead.
GTFO MY FB :lol:
