concise list of whats left from gpx wreck
- cjam
Finally I have put together a list of what parts I have left from wrecking my 1995 Black Tiptronic GPX and I have added prices for each item too. But I just want to get rid of everything so im pretty flexible. Im located in St Clair, Western Sydney and you can contact me either through the forums or via my mobile 0423 848 671.
Gpx crank shaft $20
Gpx engine block $40
2 x alternators (both work to an extent but need reconditioning) $25each
The fan that has the steel shroud. $10
The heater box $40
Glass from drivers side door. $20
Drivers side door with no internals $40
Passenger side door with glass and window motor $60
Front struts and springs (aftermarket, not sure of brand, marginally lower than standard i believe) $60pair
Rear struts and springs ( GAB super adjustable damper, again slightly lower than standard) $60pair
GPX head, completely assembled with all valve train and rocker cover, firewall side head) $50
Gpx cams from the other head. $15pair
Rear stock stabilizer bar $25
Passenger side fog light/blinker pre-facelift $20
Steering column and stuff attached like key barrel and blinker switch $20
Stock scissor jack $10
Full set of coils and leads $30
Rear wheel hubs, arms they are attached to and discs. $20 each
Stock space saver spare tyre $15
The tiptronic shifter tower $15
Fan box $20
Passenger dash airbag $40
Gpx inlet manifold $20
Gpx throttle body $15
Gas boot struts $20 pair
Rubber boot seal $15
Brake booster $30
Gpx sump $15
Boot/Fuel cap release lever and cables. $15
Plate that sits between auto trans and block $10
Handbrake cables $15
The other box under dash associated with heater and ac $20
Fuel flap $10
Antenna extension lead 3m $10
Pair of number plate lights $10
Rear window brake light $10
Entire cars wiring harness with fuse boxes $40
4 x Abs wheel sensors $5 each
Cam gears from dismantled head $10 pair
Engine oil dipstick $5
Window washer jet motors, front and rear $5 each
All four engine mounts $30 each
Steering rack with tie rods and rack ends $40
Power steering lines, pump & resovoir $40
Pedal box $20
Momo look alike steering wheel with boss kit, almost new $30
Auto flex plate $10
GPX harmonic balancer $20
Map sensor $35
Throttle cable $15
Bonnet release cable $15
ECU $35
Air bag module $30
Boot lid with GPX wing $40
Left and right front quarter panels $35 each $60 pair
Main piece of the dash, the piece that is the full width of the car. $20
I also have an entire GR non mivec motor from exhaust manifolds to inlet manifold dissassemled, happy to sell as the lot or in parts.
Gpx crank shaft $20
The heater box $40
Fan box $20
Brake booster $30
Gpx sump $15
Fuel flap $10
Pedal box $20
Auto flex plate $10
Map sensor $35
Throttle cable $15
ECU $35
Air bag module $30
- bushido
Re: concise list of whats left from gpx wreck
can I have dibs on the rear hubs, throttle body?
Are the rear wheel bearings noisy by the way?
- jwa
Are they both straight?
i will take this, could you check the postage to WA 6107
- elusi0n
What condition are the engine mounts in, and are they the lower ones? Cos if they're good and they are i'll take them....
If you can't be good, be good at it!!
- millsy
would i be able to grab a center console lid and the ignition failure sensor off you? if they are for sale :s thanks mate
- KTB_22
dammit i was going to ask about the engine mounts too.
sadface
and the boot.....
and the boot.....
- Kustom
Your getting new onesKustoms_GF wrote:dammit i was going to ask about the engine mounts too.sadface
and the boot.....
- KTB_22
How do you know these ones arent fairly new? theres a big difference between $110, and $30.
- Kustom
Well yes depends on the condition but then youd need postage on top still.. id prefer to buy new ones to be on the safe side.Kustoms_GF wrote:How do you know these ones arent fairly new? theres a big difference between $110, and $30.
He has all 4Pomwa wrote:What condition are the engine mounts in, and are they the lower ones? Cos if they're good and they are i'll take them....
PM Sent regarding parts..
- vipfto
Do you two really not communicate face to face at allKustom_FTO wrote:Well yes depends on the condition but then youd need postage on top still.. id prefer to buy new ones to be on the safe side.Kustoms_GF wrote:How do you know these ones arent fairly new? theres a big difference between $110, and $30.
- Kustom
Yes we do, just keep in mind, we don't live together.
- Gholdwayne
holy hell! ima visit you after work! finishing around 5~6.
Please PM me your addr!!!
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- Gholdwayne
Also PM me your number so i can textyou , by the way, im having dibs on weatherstrips if you have them.
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- rock_it
When you say brake booster... It is the plastic part that holds the fluid yeah .. If so I'll take that and the stock scissor jack..
You gonig to be anywhere near the FTO meet on Sunday ??
- Ollie
Pm sent for pwr steering pump n lines.
- cjam
Re: concise list of whats left from gpx wreck **updated li
This list is updated now and ive dropped a few prices.
Gpx crank shaft $15
Gpx engine block $30
1 gpx alternators needs reco and pulley $20
The heater box and core $40
Drivers side door with no internals $30
GPX head, complete with all valve train and rocker cover cams and gears, firewall side head) $50
Fan box $20
Brake booster $30
Fuel flap $10
1 of number plate lights $5
Pedal box $20
Auto flex plate $10
Roof Liner Great condition $20
Aliminium bar annodised blue that goes between rear exccentric camber bolts $25
Plastic GPX engine cover half painted orange but dodgy, not damaged just half painted... $10
Gpx crank shaft $15
Fan box $20
Brake booster $30
Fuel flap $10
Pedal box $20
Auto flex plate $10
- zuihoujueding
Maybe you should update on which parts are left?
- vipfto
cjam wrote:This list is updated now and ive dropped a few prices.
Gpx crank shaft $15
Fan box $20
Brake booster $30
Fuel flap $10
Pedal box $20
Auto flex plate $10
still after wing with or without lid.... did you get previous pm? will you post to sa?
