hey,
what oil should i service my fto gpx with???
what oil should i service my fto gpx with ??
- FTO2sxy
- GPXXX
- rxboy
The quality of oil you can use really depends on how often you replace it. If you are replacing it every 5000km, like I am because of my warranty requirements, then you can probably even use K-Mart oil
If you run your car for longer distances, say 5000-10000 km, then definitely use higher grades.
The best oils can last you up to 15000 km before you should really change them.
- JagerMarty
