My horn isnt working.
Hello all, just attempting to fix a couple of minor little problems yet again.
I cant get my horn to work and its not getting power to the connections at the horn. I have checked the fuse, the connections at the steering wheel and the spring loaded contact is all touching and clean etc. What else could it be?
Is there a horn relay or something or other im missing. Horns on both side arent getting any power?
Any help is much appreciated. :D
Re: My horn isnt working.
yip just trace wires and you will find where prob is
does run a fuse but sure that runs lots more
lol trace a wire? thats gotta be near on impossible?
silverGPX wrote:lol trace a wire? thats gotta be near on impossible?
Depends where it's running to, unless you feel like pulling the dash out...
sh*t, I wouldnt be spending any more than ten minutes on a horn. If you cant find why it has lost power just run a new power wire. 3 minute job.
lol i spent that ten minutes checking those things above. And by running a new power wire from where? interior fusebox to horn?
Yup,
