engine compression test
zuihoujueding
Post by zuihoujueding »
Compression test result:
1 - 190psi
2 - 185
3 - 190
4 - 185
5 - 195
6 - 190
mechanic said engine is fine, as long as theres no more than 10% difference between the highest and lowest psi readings.
just curious how much psi is a perfect 6a12 engine hold? 200psi?
Re: engine compression test
190 is pretty much on the money there
zuihoujueding
ok, what about brand new 6a12 GPX engine? what psi do they hold? so i know how much mine have lost over the years.
elusi0n
Post by elusi0n »
just a quick question. Where did you get your compression test done and how much was it?
zuihoujueding
Autotech at worldsquare, city. $99
