got a noise
spency
got a noise
Post by spency »
i've noticed over the last week or so, i've got this screeching/whining noise coming from the drivers side of the engine bay.
not sure what it is though, just wanting some opinions?
Re: got a noise
More than likely your alternator & AC / PS belts. Time for a change.
Check the tensioners they use when you pull them off too.
spency
Re: got a noise
Post by spency »
costly to replace?
Re: got a noise
Not much but I know it's under $100.00. Too long ago!
Re: got a noise
$30 per belt (2)
real easy to put on yourself
spency
Re: got a noise
Post by spency »
it'd be easy if i wasn't a retard.
Re: got a noise
lol, at least you're honest.
I'll do em for a case of beer.
spency
Re: got a noise
Post by spency »
you pay for travel expenses and its done
Re: got a noise
Where are you spency, I will also do for a case of beer if your qld
spency
Re: got a noise
Post by spency »
tasmania. i could failboat it over to the mainland but i'm pretty sure that would cost more then it would for a mechanic to do it...
Re: got a noise
Seriously very easy to do your self. a mechanic shou;d only charge you about an hr's worth of labour and just get the belts yourself. $150 tops and you are done.
Re: got a noise
Tassy!
Well my interstate rate is the same for beer, but must add hookers & coke.
Re: got a noise
I cant see a mechanic charging you more than 50 bucks to do it. It would literally take him 5 minutes.
zuihoujueding
Re: got a noise
Post by zuihoujueding »
Bennoz wrote:Tassy!
wahahaha!!!!! thats our president! live for beer, die for whore! :P
