Front indicator replacement Q
FTO84
Post by FTO84 »
Gidday.
I have, in the space of a month, had both my left and right front indicators die. :roll: Have purchased replacement bulbs on the weekend, but then encountered a problem - how do I remove the front fog light assembley to replace them? There seems to be one screw holding it all on, but when I turn it, it just turns without actually coming out (as in the screw housing just turns with it) and it's not something that pliers or anything can reach to hold it. It's pre-facelift
Am I missing something amaizngly obvious and am a complete car noob (highly likely :oops: )... or? Can take some shots tonight and post if it helps. :?:
Thanks, Kev
Re: Front indicator replacement Q
ther is two screws actually but you need only undo the one closest to side of car.
just remove fully then with a bit manouvering the whole pod will come free and out then just disconnect wiring connectors and replace bulb, real easy ;)
Sounds like the screw is cross threaded. If you can pull on the light while screwing it, you may be able to work it out, otherwise, itll be bar out of car im afraid.
    or you can change bulbs still with it on car just bit fiddly but can be done
    Just go in from the wheel arch, might have to loosen the splashguard though.
    FTO84
    Post by FTO84 »
    Nah gunna take the full bumper off when I have time next - might as well change the front mesh at the same time.... Though I may come back on here in need of help from someone to get the front bar back on.... :lol:
