Intake Manifold/Plenum Missing Bolt
elusi0n
Post by elusi0n »
Hey, was just wondering if anyone has 2 spare manifold bolt/nut that i need. The one i need is illustrated below. I was changing the rear spark plugs yesterday and it was getting dark so i started rushing and dropped both of them. They are sitting underneath the injector rails now and i dont really want to remove the injectors to get to them.
The ones in the blue circle are the ones im missing.
Thanks guys.
Re: Intake Manifold/Plenum Missing Bolt
Well if I was you I would be getting them out. It's not good having bolts floating around the engine like that, they could find there way to your timing belt then you could be saying bye bye to every thing.
elusi0n
Post by elusi0n »
hmm thats a good point there, thanks aza. But if anyone does have a spare let me know just in case i dont find them.
I may have some laying around some place :D
elusi0n
Post by elusi0n »
If you do, that would be great. Just let me know if you do find some spare and we'll go from there. Thanks Aza :)
I have had a look in my box of bits but no luck mate sorry.
those ones are just nuts also have a washer under them just get any replacement from hardware shop
I hope you didnt remove manifold and drop then into motor?
bduffman
Post by bduffman »
yea was bout to say there nuts. theres some thing that clamps under my one on the right, forget what it was just remember having to put it back under befor tightening it back up, i think it may be a 10mm nut at max 12
Buy a $5 magnetic pick up tool from any auotmotive store. Will get them out quick smart.
elusi0n
Post by elusi0n »
No worries Aza, thanks for having a look.
Yeah i think their nuts not bolts sorry and I made sure i didnt drop anything into the motor. I started the engine after everything was put back together with the 2 nuts missing. Everything seems to run fine but im abit worried about the missing nuts. Like Aza said it might find its way to timing belt.
Thanks for the suggestion I8A4RE i'll proberly go buy one those magnetic tools and give it a try. If not i'll have to remove the injectors to find it. :?
Go to your local autoshop and buy one of those magnetic gadgets that work like an aerial for around $10. That should fish your bolts out.
    elusi0n wrote:No worries Aza, thanks for having a look.
    wouldnt be worried about finding its way to cam belt more if they are in one of the heads this will totally destroy your motor valves pistons etc. If it were me I would not have even thought about starting it until I had located them
    Nah, I dont think its in the heaqd, but more on the head (below the fuel injection rails). Ive dropped a few nuts there myself. Bugger of a job to get them out.
      I see now, you can just remove fuel rail without removing actual fuel line will make it easier to find them
      elusi0n
      Post by elusi0n »
      Just a little update on my situation. I got around to finding the 2 nuts that i was missing and now feel at ease when driving my car around :) . Thanks to I8A4RE's suggestion, the magnetic tool helped a lot. Saved me from taking out the injector rails.
      Thanks for all the help and suggestions guys.
      No worries mate. Glad you got it sorted. They are a handy little tool
