hey guys went to get food tonight and was in drive threw when i saw smoke/steam coming from engine
now the drive threw is painted green with coolant
few weeks ago i realised one of the heater hoses was broken
not the hose but the part it gets pushed onto had snaped in 100 bits
my question is what part will i need to buy to fix this wil it be a new heater core
or will it be piping to the heatercore and where can i get this dstocks ? or mitsi or wil i have to go threw camskill
heater core hose
- bduffman
Re: heater core hose
OK, in the short term, circumvent the heater core by joining the 2 hoses together. Buy yourself a couple of 19mm irrigation elbows from bunnings (about $2 each) you also need about 10cm of 19mm irrigation pipe and 4 hose clamps. This will get you out of trouble in the short term. I think I might have the pipes you need 2nd hand. They connect to the heater core. Now, I can safely say this is an absolute bitch of a job. You need to remove the dash and centre console and then remove the heater units at the back of the passengers footwell. This will provide access to the heater core. You need to remove it from the unit and remove the old pipes and screw the new ones on and them put everything else back in. Its going to take at least 2 hours work, but because im guessing you havent done it before, allow 4 hours.
cheers
cheers
- bduffman
yea add one to my shopping list still desiding what to do with the roof, will talk to mate this week and work out what to do, yea thats fine consols wil come out when i get the new ones any way, so i can do it all in one hit, yea ill get my step dad to fix up the hoses tomorrow as i have work , thanks and how much for the hoses
