SRS Light.
SRS Light.
I just had the RH driveshaft replaced and since then the SRS light has stayed on.
Any ideas why this is?
Re: SRS Light.
$50 its grease on the sensor
Re: SRS Light.
SRS that's the air bag :?
Re: SRS Light.
Bennoz wrote:$50 its grease on the sensor
Where is the sensor located?
Could I clean it myself without a hoist?
Re: SRS Light.
Bump.
It's not effecting the driving of the car but it's annoying :?
The general area that I should have a look at would be great.
Re: SRS Light.
Bump again.
Re: SRS Light.
Well I havent had a lot of experience with the srs on a fto but the first thing I would do is disconnect the battery for 5-10 mins and reconnect (that resets ecu). If that doesnt get rid of the light, take for a quick drive and check error codes.
Re: SRS Light.
I8A4RE wrote:Well I havent had a lot of experience with the srs on a fto but the first thing I would do is disconnect the battery for 5-10 mins and reconnect (that resets ecu). If that doesnt get rid of the light, take for a quick drive and check error codes.
I've had the battery disconnected many times with no results.
I'd have no idea how to check error codes but don't worry, I'll utilise the search function ;)
Re: SRS Light.
