Hi,
I just bought some new Aero Wipers from RB Performance, problem is I can't figure out how to get the old wipers off.
There doesn't seem to be anything to unscrew/unbolt - do you just need to use a whole lotta force??
Thanks.
Pete
How do you remove the windscreen wipers?
- peterm3150
- mr-charisma
Re: How do you remove the windscreen wipers?
12mm socket + socket wrench .. pull off the little plastic piece at the base of the stock wipers & you'll see the bolts..
just be careful not to smack the wrench into the windscreen when you crack the nut..
