tcl, and engine problems
Dempsey
Post by Dempsey »
after parking in town i set off home and as soon as my turned the keys in the ignition the traction control light came on, no biggie just turn it off again, but no luck the switch did nothing and the light remained on...about 500m down the road the engine management light came on...
i took it easy on the way home and i want to know what the problem is before i start it up again and wreck the engine
any help on what the problem is or what it might be and especially how to fix it is greatly appriciated :D
Re: tcl, and engine problems
firdt thing is check error codes (do a search on here you will find how to do it)
Dempsey
Post by Dempsey »
before i start messing around with the electronics do i need to do the error codes setup and ground the pin so the codes are shown?
Dempsey wrote:before i start messing around with the electronics do i need to do the error codes setup and ground the pin so the codes are shown?
Yes mate you do , thats what vipfto, just said.
