Replacing Cam seals?
Note there is no DIY on it.
Curious on how much of a s*** it is?
I realise things like remove manifold and rocker covers and all that.
But re the actual seals themselves.
I'm curious on how one would go about it?
I'm hoping its as easy as I think.
Anyone?
Anyone?
- vipfto
A bitch of a job
1.Remove intake manifold
2. remove harmonic balance
3. remove all belts and timing covers
4.remove timing belt
5.remove rocker covers
6.will have to put spanner on flat of cams to enable you to remove cam-gears
7. replace seal, may as well do all other seals (crank, half moon) tensioners and waterpump while at it and timing belt
8. put all back together making sure timing is correct etc
so really simple really apart from the fact of a whole 10cm to work with
Basicall that is how it is done so in short its not easy and unless you are confident and have a whole day (maybe more if you havent done it before) set aside, wouldnt recommend doing it yourself
well, that put me off it.vipfto wrote:4.remove timing belt
farrrrrrrrr keet.
great.
- FTO-BOY
- FTO-BOY
- Dan25
Re:
Excuse my mechanical ignorance...Bennoz wrote:Do the bodge. Degrease the areas, pack in the gasket goo.
What does this entail? Just applying the "gasket goo" to the external areas of the engine where you see the oil leaking from?
Also, what's the actual name for above said item and where would I get it?
My leak is getting worse and I can't afford thousands of dollars to have my engine pulled apart...
- vipfto
Re: Replacing Cam seals?
its called gasket goo
and yes that is exactly what he means just put over where leaks are. But in saying that will have to be fixed at some stage and depends where leaks are from
- Dan25
Haha why am I not surprised...its called gasket goo
Hoping to have a full time job and a brand new car by then...But in saying that will have to be fixed at some stage
