Engine hesitates when cold...
- snicholmeister
Had this problem since I got the thing - basically the engine doesn't seem to work in a smooth way when the car is cold. I've done a quick search but having trouble thinking of the wording to use. It sort of hesitates and I accelerate more and it goes after a moment or two.
Does not happen after it warms up, which doesn't take long. I thought it may just be an idiosyncrasy of FTOs but no other car I have had does anything like it. We're talking fairly low RPM here - no more than 4,000. Idles fine, no other complaints apart from a friend who says the tappets are loud (unsure, will check at 100k service).
Also I am led to believe I am one of the lucky people who have a GPX with an LSD. I understand the oil needs replacing every 80k but as there's no log book I don't know if it's been done. Also don't know what type of oil to use. I've seen another thread on the subject but it doesn't really have any conclusion. Also I don't really want to use any 'awesome' oil, I'd much rather stick to manufacturer specifications (to the letter, ideally).
Any opinions on either of the above??
- snicholmeister
- aza013
- NSW Coordinator
Sounds like it's running rich at startup as this will make it bog down when you give it a little tap with the right foot. Has it got a piggyback ecu?
- snicholmeister
Erm.. no piggyback ECU as far as I know, just a Field SFC VTEC YO!!!!!/MIVEC Controller. Also says "8 Point Fuel Controll" on it (double-l and all). I assume it piggybacks off the stock ECU - dunno if it counts though.aza013 wrote:Sounds like it's running rich at startupBasvthis will make it bog down when you give it a little tap with the right foot. Has it got a piggyback ecu?
The one time I unplugged it and ran the car it sounded like the timing was off or something. I plugged it back in quick smart, runs well now.
- FTEvolution
Your 100k service would include those anyways. Have you checked air-flow meter (if it's non mivec) because those can cause issues like that if clogged. What about checking all of the many vacuum lines around the engine? If any of those are split the same can occur (I had that issue on my old skool VG20ET Maxima).snicholmeister wrote:Unknown. Guess I've got more stuff to add to the list for 100k servicevipfto wrote:that will be either fuel or spark
so how old are your leads/plugs/fuel pump and or filter
Also, as said above it could just be running far too rich. When it does it do you get small clouds of black smoke out the exhaust?
Smooth and sleepy
Smooth and sleepy
- snicholmeister
- FTEvolution
- snicholmeister
Hah, fair enough.
I've been wondering about the Field Mivec controller though - what exactly does it do? Good or bad? Anyone got any experience?
A friend suggested that I unplug it and then run the car for a while to see if it returns to normal. He said the ECU should 'learn' based on the conditions. If it is making it run rich then I'd prefer to return it to stock (better economy, better reliability).
- Dan25
- snicholmeister
- vendall
