New Engine
Pkat
New Engine
Post by Pkat »
Hi just wondering anyone know where to get or have a 2nd hand engine for my fto since the weather killed it =.=. Just a normal stock mivec 6a12 manual.
I saw a half cut on ebay.. Think it was from Japan Autos in QLD..
Other then That, try Dstocks...
Also Aza has almost a full engine.. I think...
Yep I have almost a full motor. What parts do you need?
I also have some pistons as well not a full set as two are fucked.
FTEvolution
Post by FTEvolution »
aza013 wrote:Yep I have almost a full motor. What parts do you need?
@OP (no disrespect intended Aza), but you really shouldn't look at any engine with problems like 2 cylinders gone or the like, IMO you could be setting yourself up for more problems.
Have you had any quotes for getting your donk repaired?
What ended up being the problem? Was it hydro-shock? (is that the term? when the cylinder compresses water to the limit then breaks a conrod or something).
Smooth and sleepy
The holl thing has been pulled apart and I would only sell as parts not to do a motor swap.
4 out of 6 pistons are fine, heads are fine, block is also fine.
FTEvolution wrote: no disrespect intended
none taken mate :D
I have a complete perfectly running motor its done a 160kms and I will let it go go for $800
Pkat
Post by Pkat »
o is it that sounds sweet how much do you reckon it will cost to bring it down to melbourne? sorry I8A4RE dont know where your located since your location is "BOOSTIN in front of you" lol. Also is the engine in good nick? planning to keep my old head cause just got a rebuild not too long ago but everything else ill probably need to swap. My pistons are busted, going to need to buy a gasket kit again and all that =.=.
Id say you would be looking at around $250 to get it down there. Motor was running perfectly except for the stepper motor was fucked but if you just use your one there should be no problems. Oh and I am located in brissie/gold coast
SSS Automotive in Sydney have a half cut if u get stuck, 6A12 Mivec but auto. Will probably separate the engine though. Ask for Warren.
OK, ive found one in Melbourne for you with 50K odd on it for $800. Get back to me if you are interested.
    Dan25
    Post by Dan25 »
    If OP isn't interested, I think I might be. Would probably end up being cheaper than pulling apart my current engine and replacing seals.
    Yeah I'll take second dibs, for $800 that's worth getting for a spare :D
    Pkat
    Post by Pkat »
    o wow the mechanic i usally go to is charging me $1200 and + $200 for the change of oil part? for the whole repair does that even sound normal 0.0. Thanks to dstocks i can get another engine to fix the current one.
    nikhan
    Post by nikhan »
    Pkat wrote:o wow the mechanic i usally go to is charging me $1200 and + $200 for the change of oil part? for the whole repair does that even sound normal 0.0. Thanks to dstocks i can get another engine to fix the current one.
    Why not go for a second opinion somewhere else. Try Nandi's Austocare...they do good stuff.
    Dan25
    Post by Dan25 »
    Is Pkat taking this engine or not?
    seriously NO MORE than $550 to install engine mate other wise getting ripped
    just do timing belt etc on new one befroe putting in only takes 15mins that way
    Pkat
    Post by Pkat »
    i went with dstocks engine that he advertised to me. And i think I8A4RE still has a engine avaliable. Thanks
