High Idle at start up (include video of what im yabberin on)
- Curkas
Recently took my car to pretty much the only mechanic in town to try and fix this.. first time he has ever looked at an FTO.... um anyway he isn't too sure on how to solve the problem. he suggests asking you guys considering there are many of you out there with more knowledge than him or me on the car.
watch this video and listen for what im on about.
http://www.youtube.com/watch?v=e5Tn63uzF44
- FTEvolution
100 and 55 percent sure it's the stepper motor... just search these forums for "stepper motor" and you will have your answers. It's been done to death around here
Smooth and sleepy
Smooth and sleepy
- vipfto
- Curkas
- payaya
- Curkas
nah tried that. it kinda starts coughing no matter what adjustments i make to that... still does it. the next day from when my mechanic looked at mine he had a commonwhore come in doing the same thing and ripped one off another one and it fixed it.payaya wrote:Definitely not stepper. It's working fine, seems you need to just reduce your idle via the idle screw.FTEvolution wrote:100 and 55 percent sure it's the stepper motor... just search these forums for "stepper motor" and you will have your answers. It's been done to death around here
my mechanic is currently getting one in to see if that fixes it. will see what happens. all i can do is wait. haha....
- payaya
- Curkas
- vipfto
So how long to drive to kingston from adelaide? maybe a small road tripCurkas wrote:when i first noticed the problem it was doing 3000 on startup then going to 1500 when warm. adjusted it as much as i could without it coughing. what i mean by the coughing is the idle will drop out then come back in and be like a rabbit on drugs. throttle cable is all okay played with that a bit.
- Curkas
Is it only when cold it does this or is it at normal temps too? But could be the TPS not correct either (little black thing on TB with 2x srews either side) you can loosen these and adjust it also[/quote]
Kingston is about 3 hours from Adelaide. bit more than a small road trip but not too far.
at normal temps it doesn't really cough but but when i hit the throttle it will peak it idle again and slowishly move back to normal again.
ive tryed everything with the screws. my mechanic ordered in a new stepper. see what happens...
- Curkas
tryed to get the coughing on video but camera doesnt pick it up.. haha. i have got the coughing sorted. i rekon. put it all back the way i had it before the mechanic stuff with it. umm but yeah.payaya wrote:We need to hear this coughing. There's got to be a reason why the rpm is so high.
The throttle cable when adjusted is what I consider pretty lose. So if you adjust it to what you believe it tight would make rpms as high as they are.
- Curkas
