rocket cover
brad_gpx
rocket cover
Post by brad_gpx »
attempting to take the rocket cover off
couldnt find any threads stating how to
ive undone all of the bolts and taken the plastic thingy of the timing belt aswell
but it still wont lift off
any ideas?
wicked!
can u post pics of the rocket attached to ya car?!
edit: why are you trying to take it off? do u have a torque wrench? i have this feeling you dunno what your doing
u know its stuck on with silicon gasket right? scarey
torque wrench for what?
only about 10nm per bolt back onto the head.
Id be going with the question also, why take it off if you are unsure?
and for what reason.
Also, Rocker cover, as in the tappet arms rock back and forth ;)
Don't think our cars support jet propulsion, though would be awesome :twisted:
Astron_Boy wrote:torque wrench for what?
thats not the point
oh, i get ya.
ehh :?
I built my wagon blind of any knowledge, luck and bullshit happens together sometimes :P
lol... exactly...
'ohhhhh thats what the service manuals for'
i think hes attempting the tappets... hope he has some spares... $35 each from memory
Re: rocket cover
brad_gpx wrote:attempting to take the rocket cover off
any ideas?
Undo timing cover
remove all 10mm head bolts
remove coil packs
then you can remove last bolt
gasket is actually rubber one or cork not alwasys siliconed on
may require a light tap with a rubber mallet to free up then will just lift off
For what reason? other to adjust tappets (GPX or replace if GR) or replace plug seals or gasket?
Just be very careful not to drop anything in there or could be terminal on engine
had rubber one with silicon... never heard of cork before?
brad_gpx
Re: rocket cover
Post by brad_gpx »
any ideas?
Undo timing cover
remove coil packs
cheers
oil leak so trying to find out where its coming from
Just replace the gasket with a bit of goop for good measure.
Don't fiddle with the gear underneath unless you know what you're doing!
Have fun with the head against the firewall!
would of been easier to find leak via degreasing and cleaning motor then running for awhile to clearly see leak and trace its origin ;)
sublime19
Sooty!
Post by sublime19 »
SchumieFan wrote: can you post pics of the rocket attached to ya car?!
:facepalm2:
