TIMING BELT REPLACEMENT
- Albert
http://cgi.ebay.com/FTO-2-0-GR-GX-TIMIN ... 3ef5855aea
1995 GR
Hi guys i saw this on ebay what do you think????
Also if not what parts do i require to change timing belt.Part numbers if possible?
Bosch a good brand??
cheapest place to buy it?
I already have the water pump from Camskill..
Thanks
1995 GR
Thanks
- Albert
The Dayco kit on ebay, is that for all FTO GR.
http://cgi.ebay.com.au/DAYCO-TIMING-KIT ... 518ca5568d
at $196
or
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
at $160 with idle bearing added
.Should i get it looks cheap azz
The service im doing is 100km service.
All fluids changed
Timing belt and alternator belt. any other belts to change?
Let us know, not sure what is better. I have a spare alt belt already. hmmm
Thanks
at $196
or
All fluids changed
Thanks
Call your local BSC or CBC bearings and ask them for dayco timing belt kit Part # KTBA087
- Albert
i found the Dayco: without Hydraulic Tensioner
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0251996813
CBC Bearings selling the whole kit for trade price $290 +gst
do i need to buy a Hydraulic Tensioner?
ive done 200000km
ive done 200000km
Well i just brought timing belt kit from BSC, cost me $164 thats without the AUTO tensioner. Youwont really know if you need the auto tensioner until you have it apart. But if you can get it cheap enough then get one. Mitsi want $330 for genuine bahahahaha... yeah right. I ended up grabbing a secondhand one from vipfto.Albert wrote:i found the Dayco: without Hydraulic Tensioner
ive done 200000km
$292 with tensioner is a bloody good price
- Lee85
Nah mate that is GR ONLY, the GPX belt has more teeth on it so it is different. Im not sure on the part number for the GPX.
Just give a call to one of the companies I mentioned above and they will help you out
