Hi guys
I need help.
I was compression testing my engine (in the car, just out of curiosity) and I can't get the tester out of the spark plug hole.
The problem started like this: the tester a rubber hose with a generic connection and then some adapters. I performed the test and was happy. I removed the rubber hose and started putting the spark plugs back but the adapter stayed. i didn't notice till it was too late and the adapter is now torqued up.
In a moment of brainlessness I then decided to add super glue to the rubber tubes generic adapter rather then find a reverse threaded bolt to fit.
Now everything is stuck. Any suggestions?
phenomenal *uckup
- Dras
- Dras
Ok, here is a picture of the kit I am using:
So, the adapter is torqued up where the spark plug should be. The rubber tube with its metal threaded connector is glued in to the adapter.
The adapter that is where the spark plug should be looks like this:
I am thinking I need something like this:
The problem is that hammering the aluminum tube into shape isn't strong enough. So I am now going to see if I can get something fabricated. Any other suggestions or recommended fabrication shops are welcome.
- AJ
- Dras
- Dras
Man what a pickle, you have found yourself in.
Personally i wouldnt be putting any sort of glues down there it may end up going where you dont want.
I would go along the lines of finding pipe that is about the same size or .5mm smaller than adapter and then get a hammer and light tap over adapter, maybe even a socket would work. Along the lines of what you were thinking in the bottom picture
- Shane001
The other thing to be careful of is u don't get any bits of metal down in the chamber...
When u say u torqued the spark plug, this should only be wrist tight. Can't u get a screwdriver down beside the adapter and lever it around on the knurled grip.
Maybe take one of the adapters to a bolt or tool shop (maybe Total Tools) and see if they have a socket that might grip it.
Good luck.
Good luck.
