wanted
kenny711
wanted
Post by kenny711 »
I need a gear stick ( the threaded portion of the stalk has broken off so that the knob can't be re=fitted), the indicator/headlight switch assembly and a space-saver spare wheel and fittings for my newly acquired 2 litre automatic/sports manual 1995 FTO GPX . I'm in country SA. Many thanks :D
Prety sure I've got a spare gear stick at home. Will check tonight for you :)
Ive got the indicator assembly as long a you DONT have a rear wiper. Also have a number of space savers
    pete_gpx
    Post by pete_gpx »
    dstocks wrote:Ive got the indicator assembly as long a you DONT have a rear wiper. Also have a number of space savers
    Hmm, on that note, would you have the bolt which threads through the centre of the space saver to the chasis, keeping it from bouncing around? I'm missing that on mine, annoyingly clunks around in the boot when I go over bumps.
