My lock nut key is bent/thread is worn, anyone know the best way to get the nut out? i heard at bunnings theres a bulldog nut (or whatever its called) that can eat the thread on the nut an take it out?
weld a rod onto it an just pull it out? what im thinking is im prob try go home an hammer the key see if i can get it back to place an secure as much as possible. but thanks for the advice anyway
ooo, u suggest like a tyre shop or my mechanic? cause my last lock nut i went to a tyre shop, they just use a smaller size socket, and hammering it in the lock nut to get new thread. it looks painful.
i ripped off half of my inverted hex key into a nut once... if your lucky like i was you should have enough room on each side of the nut to bash a large socket onto it.
ok so you get a socket which is 1mm smaller the nut, bash it onto the nut so the nut get stuck inside the socket... attatch your socket bar to the socket... then turn left... job done.
you must be willing to sacrifice the nut and socket piece though
ok update, lol i manage to get 17 out just 3 left, by hammering the lock nut key, but those 3 left ar real tight, lol, and 1 key (i have 2) is start to break lol
