Oxygen Sensor
Oxygen Sensor
Hey all is there a test you can do to see if your oxygen sensor is 100%?
thanks
smorison
The Godfather
Re: Oxygen Sensor
Post by smorison »
payaya wrote:Hey all is there a test you can do to see if your oxygen sensor is 100%?
thanks
pretty sure it spits out error codes, check the FTO Manuals (techincal ones)
efteoh
Post by efteoh »
under your dash to the left there is a system connector, short pin 1 to ground and turn the key to on, your enginge light should flash error code 1 - 1 to signify error code 11
smorison
The Godfather
Post by smorison »
efteoh wrote:under your dash to the left there is a system connector, short pin 1 to ground and turn the key to on, your enginge light should flash error code 1 - 1 to signify error code 11
either that or take it to your mechanic who should have a MUT-II device that will tell him the error codes
Chiangstar
Post by Chiangstar »
when you ground pin 1 for the O2 sensor and it flashes error code 11, what does that tell you? i was looking at the disgnosis box thing the other day and i couldnt make any sense of it....if it flashes when you ground a particular pin, what does that mean?
i was looking into this too cos i think my mechanic took out my O2 sensor when he installed my extractors and flex pipe....and i dont think he welded it back into the new flex pipe.....so im running an open loop...running rich and getting bad economy :(
smorison
The Godfather
Post by smorison »
Chiangstar wrote:when you ground pin 1 for the O2 sensor and it flashes error code 11, what does that tell you? i was looking at the disgnosis box thing the other day and i couldnt make any sense of it....if it flashes when you ground a particular pin, what does that mean?
welded it???? sh*t i hope not cause its supposed to SCREW IN!
i would imagine that the O2 sensor has been cooked if he WELDED it in, and if he did i wouldn't be going there.
Chiangstar
heheheh ok sorry...i meant to say that im not sure if he put the O2 sensor back in cos ive been under the car lots of times but i havent seen the O2 sensor in the flex pipe....but i could be wrong i guess....it might be in the top side of the pipe....
