very bad news for the 6a13tt
- nvr2low
hey guys got some very bad news to tell.
yesterday morning tried to start the car had a massive clunk clunk clunk noise from the motor so i turned it off straight away. looked at the dipstick it had no oil in it at all, had a look for leaks and i know their was a very small one on the return line for the rear turbo but not big enough for all the oil to just be gone.
So i left it all day and went back and put oil in it and checkd the level and it was up past the correct level for cold. Started the car and it made the clunk noise then after like 15 seconds it went away and it sounded fine. drove it home with no problems at all oil pressure was good. Now today after work come home and try it again and it is back to a massive clunk clunk so i am not touching it anymore. Getting it trucked to the shop for him to figure out what the hell is wrong with it.
anybody got some ideas
- nvr2low
hey guys the mechanic now thinks after hearing it today. he thinks it is a broken cam shaft he is going to pull the rocker cover off on monday and check the pistons and shaft to see if they are all ok.
if it has damaged internals then new motor of forged internals. if i am lucky just a new cam shaft
- nvr2low
so ben do u think this could be the problem lol. He is going to pull the rocker cover off on monday and take a look at the inside of the motor. If the cam has snapped were do I gt a new one. Or if it has damaged the block should I go full forged or new motor. Were would I find forged stuff for the motor.
- RichardB
*cough* http://www.ftoaustralia.com/modules.php ... highlight=nvr2low wrote: so ben do you think this could be the problem lol. He is going to pull the rocker cover off on monday and take a look at the inside of the motor. If the cam has snapped were do I gt a new one. Or if it has damaged the block should I go full forged or new motor. Were would I find forged stuff for the motor.
- nvr2low
richard mate I wish I had the money to buy your motor mate. Well find out 2morow about what the verdict is.
I found new cams for 1500 on rpw and pistons for 1600 and rods for around 1700. So I dunno what I am going to do. If it is just cams broken I will buy new cams I reckon. I don't think I will find a new motor for under 2k
- RichardB
if the cams have broken (Ive never heard of that before) you may get lucky and the pistons may not have hit a valve, but worst case it could be new heads as well.nvr2low wrote:richard mate I wish I had the money to buy your motor mate. Well find out 2morow about what the verdict is.
- nvr2low
