Programming new central locking remote
- harry90
So guys i got a new remote for central locking cos i dont have a spare. Just need to know how to program the new remote so it can be used.
- harry90
- nicholas
Depends if it is the stock CLS or an hooked up to an after market alarm.
If it's an aftermarket alarm kit, you'll need the installation manual from the alarm itself.
That's what I"ve got, and i've successfully programmed a new fob myself.
But yeah, process is different for every alarm unfortunately.
Resident Asshole.
- harry90
I'm pretty certain it is still the standard central locking system because I have the usual fto central locking issues. I might just get new motors etc in the door panels to combat the whole issue. Thanks guys
- harry90
Ok so ill say the whole problem from the beginning.
I only have 1 central locking remote and the little plastic bit on the bottom which attaches to the keyring broke, so now the remote cannot be attached to the keyring and is seperated from all my keys. This is the reason i needed a new remote so now i have my old remote which is seperated from my keys and cannot be attached to the keyring and 2 new remotes which i got with new immobiliser and alarm, but only need the remotes cos i already have immobiliser and alarm and dont need another.
- pete_gpx
You can't just buy new aftermarket remotes to program into your factory central locking. It doesn't work that way.
If you have bought an entire kit, just expecting to use the remotes... No. You will need to remove your factory central locking control unit, then replace it with the aftermarket one you have purchased.
