Lower Control Arm Ball Joint
- kirksta
Hi Guys,
I just got my car serviced today, and the mechanic said that i needed to replace my the lower control arm ball joint. There i am thinking, $600 i just spent on a service, a pair of tires, and brake pads. I'm thinking crap!? Now, who much is it going to cost me this time?
So does anyone know where i can get a hold of this part or know the part number? Worst come to worst I'll have to go to Mitsubishi for it, but i don't necessarily want to put more holes in my wallet.
Please help guys, (I live at blacktown)
Kirk
Kirk
- kirksta
Front bottom arms,
Facelift and GPvR:
MR344277 MR414899 = Lefthand LH &
MR344278 MR414900 = Righthand RH
FTO's up to 1997 (Excl GPvR):
LH= MR178777 or RH= MR178778
Balljoint only:
http://www.camskill.co.uk/products.php? ... 0s10p53956
Facelift and GPvR:
Balljoint only:
If you can't be good, be good at it!!
- kirksta
i just spoke to the mechanics and they said i only need the ball joint itself. Now the ball joint available on camskill, does it fit both sides?Pomwa wrote:Front bottom arms,
Facelift and GPvR:
Balljoint only:
- Storm
As far as I rememmber you need to press it out, so basically you need a press and something to split the original ball joint from the hub.kirksta wrote:Finally got the part from Camskill, Is there a DIY for this fellas? and if so will i require special tools?
thanks kirk
- J
yeh ive read that aswell, was it 'SG' who wrote it? forgot.kirksta wrote:through some research from this forum, is it true that lower control arm on some lancers will fit the an fto? If so, does it it make more difficult to try fit it on?
something about them being bigger or harder and gives better handling. dont think its been done by any online members though. maybe 'SG' can shes some light on this
- Storm
Yup, EVO 1,2 or 3 rear arms fit. In fact all the rear suspension compenents are the same except the trailing arm has a hole though it for the drive shaft, and the shocks will probably be different.Bennoz wrote:Thinks thats the rear control arm your talking about. Was an EVO component, same as FTO but with a plate welded the bottom of it to make it stiffer.
