Boot rattles, fix?
- eddiii
Boot rattles, fix?
my boot rattles real bad when my bass is pumping, i stopped it by putting playdo (the clay thingy), it actually worked, but now they went all dry and hard so it doesnt absorb the sound anymore, any suggestion to use? are there those sound proofing clay?
- Jayvi
can get a bulk pack for round 250 on ebay, which is not too bad i guess.... im waiting for my pack to install so il give feedback after...pete_gpx wrote:Down at WOW we stock the Stinger Roadkill line. Works very well, I've heard the difference myself and isn't too crazy expensive.
[img]http://i28.photobucket.com/albums/c230/The_Hoplite/CraigBellamy.png[/img]
youve possibly done in the welds in the boot. Try siliconing all the seams
The boot skin is attached to the subframe with glue sort of stuff. An accident (or loud stereo) can split these spots so that the boot skin rattles against the subframe. The sikaflex can be used to get it better than it ever was. I have sikaflexed all the seams in my bonnet and boot. Open the boot and use the sikaflex to create a bead between the subframe and the boot skin. You dont have to do it around all the seams, but it looks better if you do. Tidy it up with a rag. Make sure you tidy it before it dries as it is not pleasant to try and remove once its on.
- harry90
- zuihoujueding
- Grue
