Intake pipe hole?
eddiii
Intake pipe hole?
Post by eddiii »
on my intake pipe, theres a hole (arnd 1cm or less) on the left side facing the engine, it use to has a blueish pipe blocking it and leads to somewhere, just wondering what is the purpose for it, and if i dont put it back, does it affect performance or the car?
JOeJOe
Re: Intake pipe hole?
Post by JOeJOe »
eddiii wrote:on my intake pipe, theres a hole (arnd 1cm or less) on the left side facing the engine, it use to has a blueish pipe blocking it and leads to somewhere, just wondering what is the purpose for it, and if i dont put it back, does it affect performance or the car?
its the breather pipe, if you don't connect it it'll suck a lot of dust into your engine.
eddiii
Post by eddiii »
where does it connect to though? i still have that blueish pipe but dont know where to connect it back to.
back to the rocker cover and yes it should be connected
eddiii
Post by eddiii »
anyone has a pic to show me where to connect back to? or can i just seal off the hole on the intake pipe?
Grue
Post by Grue »
Where the little filter is connected to if that's any help. Only pic I've got of it:
eddiii
Post by eddiii »
ok thanks, i shall try find a way to hook it bak up, but is it ok if i just block the hole instead of linking it to my pipe?
It needs to be open as it vents the vaper out of the heads.
eddiii
Post by eddiii »
Grue wrote:Where the little filter is connected to if that's any help. Only pic I've got of it:
what would i search that little mini pod as if i want to buy one?
pete_gpx
Post by pete_gpx »
Repco etc. will have one that will fit. However, I've been told that they are not legal, at least in Queensland.
Grue
Post by Grue »
^ yup, repco and super cheap have them. 'Crank Case Filter' is what I've always seem them sold as. Ebay is bound to have a decent selection.
Not legal? You chaps have some funny laws over there!
eddiii
Post by eddiii »
alrite guys, thanks a lot grue, is there any different size of them or all one size fit? :) ta
Universal, they usually have a couple of differernt fittings that come with them, so you just use the one that fits best
eddiii
Post by eddiii »
i just got 1 called mini air breather and theres 4 size, calamab14, 18 20 25, 14 is wayyy to small and 18 is abit loose, hope it fits, or anyone know the actual size if they got one already?
If its loose, just nip it up with a hose clamp.
eddiii
Post by eddiii »
thanks for all the help, i have just attached it, shall get a pics when im free
