Rear engine mount
Rear engine mount
as above I need one (new) where is the best place to buy them here? or does anyone know what other car they share?
Oh its for a manual as know they are different (the one that bolts to gearbox on rear of crossmember) looks at Dstocks :P
Camskills or just get it rebuilt and with urethane.
I can get them as well. Make sure you get the right one. They do vary depending on model and transmission type.
    Danielk
    Post by Danielk »
    I got 2 from Bursons recently.
    Was about 80$ each.
    topao
    Post by topao »
    Danielk wrote:I got 2 from Bursons recently.
    Was about 80$ each.
    F*#K my mechanic made me pay 250 each for 2 of them
    I can get you a poly one made if you like. Mine was $180 using an old mount as the donot for the shell.
    BorepYano
    Post by BorepYano »
    yeah i'll probably need a couple as well.
    can't remember which one of the top of my head but one of mine is broken, another sagged.
    any suggestions for somewhere in qld preferred?
    herfto
    rear engine mount
    Post by herfto »
    where is bursons,are they in sydney?
    Re: rear engine mount
    herfto wrote:where is bursons,are they in sydney?
    Yeah, they're like a Supercheap / Auto One type store. Just not as many of them
    http://www.burson.com.au/allstores/stor ... search.htm
    thanks guys managed t get originals rebuilt with poly dont know cost yet but will post when i get bill
    herfto
    rear engine mount
    Post by herfto »
    thanks benoz for the info will check them out
    ok so if anyone interested i got original mounts rebuilt, they stuffed up and rebuilt with standard not poly but they will do for now
    cost $60 for both (special price though) but shouldnt be a whole lot more, I did remove mounts for them however to save labour costs
    vipfto wrote:ok so if anyone interested i got original mounts rebuilt, they stuffed up and rebuilt with standard not poly but they will do for now
    Who did you get them done through?
    local workshop I do a lot of work for them so they look after me, just cost me the actual rubber mount, I didnt have time to press myself :roll:
    Right so you just pressed out the old one and pressed in the new? Where did you get the rubber from?
    I8A4RE wrote:Where did you get the rubber from?
    Ya mum's purse.
    Storm
    Post by Storm »
    Heres a thought for ya
    If the manual mounts are solid rubber, and the tip ones aren't, could you fit a set of manual mounts to a tip as an upgrade? It would certainly hold the engine better but would it damage anything? After all, they were probably made different for a reason :?
    Bill
    Ya mum's purse.
    hahaha
    yip just press out and new in, they had rubber in stock just generic but identical to factory ones
    Sweet I have a press at work.
    Can you get me some rubber?
    Oh and which ones are these for sides or front and back?
    yip i`ll get a price for you prob a little more than 30ea though.
    they were for front and rear ones
    ill be going back there next or week after and let you know simon :D
