condensation/moisture in indicator fog light cluster
bas
Post by bas »
It looks real sh*t how do i get the condensation out, im pretty sure the fog light nd indicator have seperate compartments
-Nighthawk-
Post by -Nighthawk- »
Got the same problem ;)
Thinking about taking it all apart and giving it a good sanding down and cleaning. No idea on the exact procedures and materials needed however
bas
Post by bas »
dw taking it all out nd sanding is easy but i got no idea about condensation
if u have a look theres some info on takeing the cluster out(pretty much unscrew 1 screw at the front nd push it out from behind)
nd i know theres a topic on polishing lenses
Storm
Post by Storm »
I had the same, nightmare to try and get dry, even though it does have vents in the rear which are meant to keep it from steaming up. I ended up drillling a small hole underneath and facing backwards which seems to have done the trick and allowed it to clear.
(And thats in Scotland, famous for its not-very-dryness!)
Bill
bas
Post by bas »
sorry where did u drill a hole?? nd how big? if u remember
did u drill the hole then leave or drill then dry with something?????
Albert
Post by Albert »
Storm is right...
I had disame problem for a long time
grab a power drill and small drill bit (note the smaller the bit is the more holes eg 4 you may need to do)
Step 2- aim at the lowest point where water can drain and slowly drill untill you get pass the plastic. In and out.
Step 3 - all fixed.
