Taking out some interior parts
eddiii
Post by eddiii »
How would i take out the vents in the middle console above the climate control and the two side vents, and the mirror switch surround.
thanks guys
Pomwa
Post by Pomwa »
A thin screwdriver and gentle perswation.....
If you can't be good, be good at it!!
eddiii
Post by eddiii »
ooo is it? i thought u would need to take off the whole console in the midlle to get the vents out, hopefully it will come out with your way :) thanks
Nup, the centre vents are screwed in from the back. The top console has to come out. The speakers in the dash will just pop out with a screwdriver, but if you are referring to the vents in the dash below them, you ar looking at having to remove the dashboard im afraid (again, tey are screwed in from behind).
    eddiii
    Post by eddiii »
    thanks dstock, i got the middle vents out, but the side ones seems like a biatch to get it out -_- ill see how it looks after i get the middle vents done, if it looks REALLY ODD the i guess i have to get the side vents too :(
