Head Light Query
mushilea
Head Light Query
Post by mushilea »
Hi guys!
I was wondering if there is any way, and if it is legal, to remove the pearlescent or opaque covering on the Low beam part where my HID's are.
The High beam doesn't have them, and it looks like they are restricting the HID's light =(
[/i]
if removed your normal light will be like hugh beam light too
Dras
Post by Dras »
Has anyone replaced their glass lens with one that lets more light through?
mushilea
Post by mushilea »
vipfto wrote:if removed your normal light will be like hugh beam light too
and thats a bad thing? =)
Isn't low beam aimed lower to the ground than high beam? Hence it doesn't dazzle people?
justbecause
Re: Head Light Query
Post by justbecause »
mushilea wrote:Hi guys!
[/i]
What Kelvin HID you're using???
mines is fine....
I'm using 8000K...
bear in mind the higher the kelvin the less light you get
the high beam and low beam are angled almost the same just that low beam has the lens preventing light from blinding other drivers
it is possible to change the lens but really a lot of effort and finding something suitable where a proper HID kit and nice clear light covers should suffice
col2560
Post by col2560 »
im thinking the lens is to focus the light beam, otherwise it will probably just spread out everywhere.
