how easy/hard to install one?
i wanted to buy a deck that i could hook my ipod to, is it simply as removing the old put in the new? any wiring that i need to be aware of?
New deck
JOeJOe
- vipfto
really easy just remove old one and new one fits in perfect
as for wiring just follow head unit diagram should be yellow is permanent, red is accesory black is earth and use tester (test light, voltmeter) to know which one is permanent and accesory wires from radio loom, and just earth to chassis
then connect speakers and done!
just disconnect batt if you feel you need to
