having trouble with the hand brake light, lighting up when i take off on first gear... its really starting to worry me. it happens on first gear when i "give it" a little.
PLEASE HELP!
also could be the negative pressure inside the well pulling the inside bit of the lid down- if it is - fill up the fluid to the right level and push the rubbery bit back up into the lid bit
(sorry - technical terms are NOT my strong point!!!)
Teania wrote:also could be the negative pressure inside the well pulling the inside bit of the lid down- if it is - fill up the fluid to the right level and push the rubbery bit back up into the lid bit
