0-100kph: 6.83secs
0-400m: 14.99secs @ 154.9kph
i recorded these times with a G-Tech Pro and was consistently achieving similar times (within 0.1secs). my modifications include airfilter and exhaust.
2) The units need to be recalibrated periodically as they go out of whack. The instructions on how to do this are at their forums."There are several significant improvements over the original G-TECH/Pro Performance Meter that have been implemented in the new COMPETITION model. First of all, there are 3 accelerometers and they are fully temperature compensated. This in itself is a huge improvement in accuracy. Secondly there is a very sophisticated new calibration algorithm that allows much higher precision. Also the system now has 32 times higher resolution which speaks for itself. New Noise-Correction algorithms have improved overall accuracy as well."
to get those times i practised launching at different revs between 3300rpm and 3700rpm. my best results came from launching at 3400rpm.Adriano wrote:hey twistea, how do you launch??
who knows, urs could be one of those manual GR freaks out there
i have a manual GR too, but no times as good as those... i could only manage high 8s 0-100....
gav, my freakin car has the same freakin response when i get to about 5500rpm, the intake starts to freakin roar really freakin load.G_A_V wrote:Im not sure what modification has been done to these "freak" gr's but i have a feeling it has to do with the cams (I have spent ages looking for computers, and other modifications). The reason why i think its the cams, is after installing a new airfilter the car gets very loud under wide open throttle, and when it hits 5 1/2k rpms, similar to the mivecs, but i have found no other grs which do get this loud, and also have a distinct change in power/sound (it also increases in power at around 5 1/2 rpms).
