Manual seat position preference
- Gholdwayne
Hey guys, i dont know what i want yet but how do you prefer your seating position in manual driving ? and what about the steering wheel ? how low/high?
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- col2560
- maggsy
- Gholdwayne
yeah i know about the what feels good for you thing, but i wanna try some preferences and maybe i might say " wow this one feels good, ill use this! "
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- nicholas
Okay well yes everyone is right, it does depend on personal preference. Having said that, this is what i've found out...
I'm six foot tall, and when i first started driving fto, i used to sit real close to the steering wheel (guess i really did think it was a go-kart lol).
I found that i was getting really sore shins on long drives (like big south coast drives), so i started sitting all the way back as far as the seat would go, because this helped on long drives (had the same problem in my g/fs golf, and same solution worked there too).
When I got my second FTO, the clutch action was very different, with only the last tenth of the clutch needing to be used to shift gears. So it was really good to drive sitting all the way back.
However when I did some track day driving a little while ago, we had an instructor. The first thing he made me do was move the seat forward. He said that your arms have to be a little bent at the elbows. So even though its not quite as comfortable, i do it because i know the dude is an expert. and after a while you get used to it.
so yeah, not all the way forward, not all the way back either. as for seat height... i didn't even know you culd adjuts it lol
Resident Asshole.
I had some advice from instructors too, much like the above ^^
With your back aginst the back of the seat & your arms out stretched to the wheel, the wheel should come to your wrist - so as above, your arms should be bent when grabing the wheel at 10 & 2. If you think about it, its a whole lot harder to hold a ton of weight in front of you with your arms fully outstretched, than if you were to hold a ton of weight out front with your arms closer to your body.
Seat position should also enable you to brace your knees aginst the side of the door & inner console.
In summary, if you sit the seat way back & lean right down, you're an idiot & its the worst possible driving position
but it is fuly sik.
- col2560
I concurnicholas wrote:I found that i was getting really sore shins on long drives (like big south coast drives), so i started sitting all the way back as far as the seat would go, because this helped on long drives
I typically have to sit slightly further back with the FTO typically due to my feet.
I find having size 12 feet that they will get stuck under the dash, so I typically drive toe ball.
Much like my drifting days, but without using my heel.
- Dan25
I was thinking about this today whilst driving... How far back/forward should the back of the seat be positioned (reclined)? Should it be in a position where it is holding you up vertical or should you recline it back a little further and not actually rest on it so much? I was just wondering coz i don't know if I looked like a dick in my current position...
- SchumieFan
- Delvance
Yep the arm out and wheel to wrist is pretty good guide (in Bennoz's post).
I am fairly short...only 170cm (male) and my seat position in my fto was
Seat as low as possible
Have chair all the way forward, and move the back of the chair all the way forward
THEN
7 clicks back on the recline, 11 clicks back on the slide adjustment.
(i'm pretty sure i got that in the right order lol, it's been awhile since i've been in a drivers seat of an fto
That was so perfect for me.. to the point where if i wore different shoes (thick soles for example), i'd have to adjust the slider to make up for the difference of the shoe sole lol.
Oh, steering wheel low as possible.
THEN
- vipfto
- koolio1234
Personally, I prefer sitting right up close so:
1. My knees can be bent and relaxed allowing my legs to get maximum travel when peddle dancing.
2. My arms are closer to the loading point and therefore have more control of the wheel.
3. Able to brace myself in case of impact.
4. Better perspective of my hood and the outside surroundings (more attentive).
Ideally you should do the same but its completely up to you. Height adjustment will vary according to the driver but the length adjustment is more detrimental to safety and efficiency.
