Moderators: IMC , Club Staff
biglinz
Posts: 47 jedwabna poszewka promocja
Post
by biglinz » Tue Jun 23, 2009 3:49 pm
the lifters on my 94gr are a bit noisy a friend suggested flushing after dropping the oil out as a way to clean out crud that accumulates under the lifters that cause the ticking noise
anyone hear that before or have a suggestion thanks
Posts: 23687 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Tue Jun 23, 2009 4:19 pm
Yeah, I did that once to one of my engine, works well if the lifters are just gummed up. If they're worn, you'll need to replace them.
biglinz
Posts: 47 Joined: Sun Sep 28, 2008 5:00 pm
Post
by biglinz » Tue Jun 23, 2009 4:29 pm
thanks ill give it a go
Tippin
Posts: 1663 Joined: Wed Feb 27, 2008 6:00 pm
Post
by Tippin » Tue Jun 23, 2009 4:37 pm
hmm thats interesting, never knew that
have you used an engine flush fluid yet though? it decreased the noise of my tappets a bit ...
col2560
Posts: 434 Joined: Fri Jun 06, 2008 5:00 pm
Post
by col2560 » Tue Jun 23, 2009 6:52 pm
a mechanic mate of mine used to use diesel to flush the engine, just let it idle dont rev it. 1 warning though, it might exaggerate any oil leaks, it washes away any build-up that might be blocking the leaks.
Post
by Bennoz » Tue Jun 23, 2009 8:53 pm
This is very true ^
Just be gentle with it.
Posts: 3670 Joined: Sat Sep 06, 2003 5:00 pm
Post
by payaya » Sat Jul 04, 2009 1:06 am
I took my lifters out and cleaned them with Diesel etc. Worked great for 20000kms then were back to the orginal state. I would just get them changed.
biglinz
Post
by biglinz » Sat Jul 04, 2009 10:21 am
thanks for the info have decided to give it a go. be too old to drive before i clock up 20,000 kays.
Post
by payaya » Sat Jul 04, 2009 3:32 pm
biglinz wrote: thanks for the info have decided to give it a go. be too old to drive before i clock up 20,000 kays.
Good luck mate, the rear banks are a pain to get out!
Before you try it, I recommend you go to repco and get some Nulon E20. Its an additive to your engine oil, use to work a treat for me.
My second set of lifters are getting noisy again at startup.
biglinz
Post
by biglinz » Sun Jul 05, 2009 3:26 pm
stopped me in time I'll give it a go thanks
Posts: 9594 Joined: Mon Aug 28, 2006 5:00 pm
Post
by I8A4RE » Mon Jul 06, 2009 9:26 am
Yeah that lifter cleaner is good stuff. It would keep mine quiet for about 8000km
Post
by payaya » Sat Jul 11, 2009 12:22 am
biglinz wrote: stopped me in time I'll give it a go thanks
How did you go? Get any reduction in lifter noise?
biglinz
Post
by biglinz » Sat Jul 11, 2009 10:42 am
let you know after i drive it, have been too busy. should be on the road next tues.
biglinz
Post
by biglinz » Thu Jul 30, 2009 11:51 am
sorry i took so long getting back to ya all tried the nulon 20 fairdinkum stunned me 15 min after putting it in the engine was purring like a well fed cat must say i didn't expect such a drastic improvement
Post
by payaya » Sat Aug 01, 2009 12:23 pm
Yep I felt the same way!
