Hi guys, I've just bought another FTO for my girl and it is a 95 GR Auto, everything is fine except one warning light which is located at the bottom left refuse to go off even while driving...
the previous owner said it has always been there and never went off, we took it to the mechanic and serviced it and said the car is all good but he also wasnt sure why is that light on at all times and what does it represent...anyone have any idea what does the bottome left light meant to represent? would appreciate your help, thanks
good idea I'll get a coupe of pictures put up later tonight
I checked and there is water to the windscreen washer...and I am pretty sure windscreen washer is an orangy color light on the top right hand side as i never refill mine ...
noclue wrote:good idea I'll get a coupe of pictures put up later tonight
Bottom left is your exhaust temp sensor. If your car has been de-catted this is showing an open circut.
Under the drivers seat you will see a connector which should go to the cat. Stick a fuse over the terminals and the light should go away. Failing this take the bulb out.
You only need it to show you not to park in long grass when your car is hot
