For Sale - Set of 4 Tyres - Federal ss595
mr-charisma
Post by mr-charisma »
Selling full set of Federal SS595 tyres - I'd say 95% tread, barely used the car since getting them - Asking $480
.. They're awesome tyres & I will be getting them for the next set as well, but unfortunately they don't fit properly, so I have to go with a different profile.
http://www.federaltyres.com.au/ss595
I'm in Brisbane CBD
*EDIT* 215/45/17
Jamie
Post by Jamie »
What size are they?
mr-charisma
Jamie wrote:What size are they?
215/45/17
J
Post by J »
what are the rrp on these? Interested but i need to know weather these are worth the delivery cost
HiRAEdd
Re: For Sale - Set of 4 Tyres - Federal ss595
Post by HiRAEdd »
mr-charisma wrote:Selling full set of Federal SS595 tyres - I'd say 95% tread, barely used the car since getting them - Asking $480
I'm in Brisbane CBD
*EDIT* 215/45/17
I had exactly the same problem. 205/45 17 solved 95% of the rubbing issues for me. Full lock, going up a gutter will give me a very slight touch still. But other than that, perfect.
mr-charisma
HiRAEdd wrote: I had exactly the same problem. 205/45 17 solved 95% of the rubbing issues for me. Full lock, going up a gutter will give me a very slight touch still. But other than that, perfect.
Problem isn't the width, it's the diameter.. thinking of going 225/40/17 .. hopefully they won't be too wide..
HiRAEdd
Post by HiRAEdd »
I had both problems. Too high, it rubbed on the top corners. And too wide, took a slice out of the side with the strut. So careful with the width. Good luck.
for 17`s provided you have the correct offset wheels tyre size should be 215/40x17
mr-charisma
vipfto wrote:for 17`s provided you have the correct offset wheels tyre size should be 215/40x17
Any idea what the correct offset would be?
pete_gpx
Post by pete_gpx »
You'll have to excuse me, as I know nothing about tire dimensions etc.
Would these fit a 17" rim with an 8" width and a +40 offset?
khunjeng
Post by khunjeng »
I run those some 595ss on some 17's with 45 profile, offset is +35
front still rubs a bit - I run King low springs but the wider look is great
for 17x7 it should be +42 offset.... less though for wider rims
mr-charisma
Yeah, I assume that the issue is more the profile of the rims, because the old set of wheels are 17's with the same 215/45 measurements .. I am only touching the spring housing of the strut by the smallest margins .. I was thinking of using spacers, which should resolve it, but might be easier / less illegal to swap tyres.
@ J - The retail on the tyres is about $600 odd, I picked them up for $580 something
nvr2low
Post by nvr2low »
what offset should i get for 18x7.5 with 35mm tryes
i think you mean 35 profile tyres? are they 215/35x18 or 225?
anyway think it should be around +35 offset
nvr2low
Post by nvr2low »
yeah mate 215 35 18 mate. Ok +35 sweet is that all round mate
FTEvolution
Post by FTEvolution »
I had 40's, but I think that was too much, 35 would be the go :)
Smooth and sleepy
nvr2low wrote: yeah mate 215 35 18 mate. Ok +35 sweet is that all round mate
yeah all the same just bear in mind that you still may get some rub and need just a small spacer...... but double check on that offset mate pretty sure its right though
