rear suspension help
- col2560
any ideas how to get the lower trailing arm main bolt out?? i got the nut off but the bolt won't drive out. it's the bolt through the main pivot bush.
- FTEvolution
- FTEvolution
Isn't that what I said? Jacks (take the weight off the arm), Bolt + Mallet (light tap)... Overkill? I think so, but it did workvipfto wrote:you prob need to take the weight off the arm. then it will either slide out or light tap will get it out
Smooth and sleepy
Smooth and sleepy
- col2560
- Ecnerual
just what the other guys said...
i had to actually take mine out today because it wasnt tightening
im assuming your talking about the tension pin that bolts the arm to chassis?
you have to jack it up take the weight off
spray a lubricator or an oily substance and let it sink in.. like WD-40 or something
just hit it straight out with a mallet
that will definately make it come out.. if you still cant get it out - go to gym and hit some weight and then try again
- col2560
- col2560
