dented b pillar
- col2560
dented b pillar
any ideas how i can fix this dent? can i get to it from inside the car? or is it a double skin on the b pillar?http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0306223501
is the last pic on ebay ad.
It is double skinned, but thge inside skin has a hole or 2 in it from memory.
- col2560
- Ecnerual
Ok firstly do what ben says then do what Ecnerual says with all the little dents left over. Then get some filler and apply to any dents you couldnt get out. Sand back and use hand to feel for any high or low areas. Mask off, primer sand and paint
- col2560
- FTEvolution
- col2560
What are all those little pin prick dents? They shouldnt be there
- col2560
the dents are from the round bar i used to lever the big dent out with. i intend to hammer the high spots back flat with a body hammer and dolly, then sand, bog, sand and paint prep. no worries !!!!!
the first big dent would have stretched the metal, no avoiding it. all i intended to do at this stage was to bring it roughly back to shape.
watch this space lol.
hence why you should of done what ben and i said. Your causing more work for yourself and in the process actually making it worsecol2560 wrote:the dents are from the round bar i used to lever the big dent out with. .
- DaveO
A body shop will be able to shrink that back into reasonably good shape for you with out costing you to much. just get them to go to metal finnish only as you will be finishing it. if you don't get it shrunk back the bog might pop out as the base metal flexes.
- mr-charisma
Have to agree with the rest of these guys.. should have tried using a suction plunger to try & get as much of the dent out as possible then drilled a pilot hole for a dent puller tool.. much less messy
I'm sure you could manage to get it looking just as good when it's finished the way you've done it, just a lot more mucking around.. and you might need to use more bog..
Always the way to go when using hammers (ball peen - for the love of god) is to do more hits with less pressure & if at all possible it can help to get someone on the outside of the car to exert pressure with a block of wood or something where you're hitting so you don't get as many little mountainous dents..
- col2560
- col2560
- col2560
finally got a warmish day so got it masked and sprayed, just primer and colour, no clear yet, i ran out of time and it starts to get cool about 3pm.
masked;
primered;
colour;
its been about 20 yrs since i sprayed metallic, it looks ok so far, not perfect, but about 95%. 1 trick i learned a while back is to leave the boot lid off so you can crawl through to drive it, don't have to re-mask around the door that way.
masked;
primered;
colour;
