Hi :)
trawt
Hi :)
Post by trawt »
I finally bought myself an FTO!
Love this car.
Just one question though, is it difficult to replace the backlights behind the vac/oil gauges? (This isn't likely to be a fuse, is it.. nothing else is affected.)
Yup i'm a total noob.
Thanks. ;)
FTEvolution
Post by FTEvolution »
I have never heard of lights blowing in those, AFAIK they are LED's. I would check fuses for a start. There is a DIY on here somewhere for removing the housings etc that hold them.
Smooth and sleepy
WTTC and yes they are fused start there or the power wire to them maybe earthing out..
I had this prob long time ago so just changed them to oil pressure and temp gauges
Welcome to the club ... I had to read your name a couple of times ... I really thought it said Twawt ... :oops:
Anyway ... Yeah, not sure about the problem ... Is it a stock or aftermarket gauge :?:
trawt
Post by trawt »
Thanks :]
It looks like they're both stock (mits logos).
Had a quick look at the fuses and they seem alright. Might have a more thorough look at fuses soon, and i guess when i get some time i'll try taking the centre surround off.
I have the oil one ... It is a sh*tty yellow light ... Mine didn't light up as there was something wrong with how it was installed... I corrected the wiring problem, and disconnected it as it looked fugly ...
trawt wrote:Thanks :]
from memory i think the fuse is under hood for those ;)
Oliver89
Post by Oliver89 »
Welcome to the club. :) Enjoy.
Proud Owner Of a White ( Version R ) Aero Series 1998 Mitsubishi FTO 24v 2L Mivec Engine. Fresh Import.
[img]http://img197.imageshack.us/img197/2568/fbsig.jpg[/img]
Welcome :)
INVECS
Post by INVECS »
Ahoy :)
