My mate bought semi-slicks racing tyres and magz and wasnt using these anymore so he gave me a fantastic deal of $350 to which i couldnt say no!! 17's with fat rubber. Amazing grip i must say!! Next iam going to lower it when i get my suspension upgraded.
sorry to inform you that tyre size is wrong by along way and they arn`t semi slicks just some dunlop or sava intensa am i right?
should be 215/40x17 your speedo will be a mess and when lowered will most likely rub
id be picking they came off a falcon or somehing?
They are dunlops. And I didn't say they were semislicks. I said my mate wanted to get semi slicks. And yes they will rub, but iam getting 20mm spacers when I lower it. They came of a supra.
Plus iam not too concerned at all!! Got them very cheap so even when I sell them a year or two down the track I'll still make my money back! They don't rub at full lock nor do they rub on speed bumps and kerbs. So I'll only need spacers when I drop it!
seriously instead of spacers invest the money in some good quality rubber those dunlop sava are the cheapest and nastiest of there range you will notice it in the wet
also go for the right size as i already said your speedo will be all up the f**k
vipfto wrote:seriously instead of spacers invest the money in some good quality rubber those dunlop sava are the cheapest and nastiest of there range you will notice it in the wet
you may be able to even trade them in??
Would it be changing the speedo much?
To my understanding, increasing to 17" wheels adds roughly 25mm to the diameter, and then he's decreased his tyre thickness by ten, thereby reducing the diameter by 20mm which is a gain of roughly 5mm diameter, which is still within the acceptable guidelines -25mm/+15mm.
not really the tyre is 235 and the profile is 45 which is 45% of the aspect ratio of the width of the tyre NOT 45 MILLEMETRES as some people think.
so with a 215/40 tyre the profile is 40% of the width which is only 215
so he has a tyre which is to wide already and then the profile (sidewall) is far to large so total diametre is actually much more hence f**king up speedo
if you check out tyre calculators the 215/40x17 is almost perfect in comparison to the stock 15 or 16 inch tyre size
J wrote:loving the metal halo's in the lights mate
I didn't even notice them .. they look awesome.. would be cool if someone could make some to slot in there ... like the aluminium dial rings fit in the speedo cluster..
vipfto wrote:not really the tyre is 235 and the profile is 45 which is 45% of the aspect ratio of the width of the tyre NOT 45 MILLEMETRES as some people think.
sorry to offend but im gonna have 2 call that car a afail
tacky rims
chrome moulds
whatwvaer those things on the roof are
na to many stle clashes bro but thats just my opinion
