im trying to pull out my seatbelt but it seems to be stuck, i had a look at the seatbelt mechanism and im not sure but i think the weight mechanism is dislodged or soemthing because the tooth on the spool is always engaged with the pulling mechanism
does anybody know how to fix this?
stuck seatbelt
- 8u8813f1uff
- koolio1234
- pete_gpx
Hmm, as far as I was aware, pre-tensioning seat belts should never be dismantled since there is a small explosive device located in them, designed to quickly detonate and lock the seat belt under extreme pressure, hence preventing you from flying around when a vehicle rolls etc. Tapping the wrong thing while attempting a repair could be dangerous, if this is the case.
Could be wrong. Someone correct me.
- Shahrez
- koolio1234
yeah I thought so.Shahrez wrote:i had the same probleml and i had opened it up and its all safe just a metal coil and lots of gears really. should be alright!
I think some sort of centrifugal locking mechanism was responsible for the seat belt locking under instant pressure. I've never opened one up though so I wouldnt know.
- 8u8813f1uff
