DASH Lights
- ft04me
DASH Lights
Hey guys..
i tried replacing my Main Dash globes with some red LEDs ...
when i did it non turned on and when i put the original bulbs they too didnt turn on?..
now i have no lights in the dash except for thos little warning light ie "doors open", "low petrol", "highbeam" etc
does anyone know what could have went wrong?
- Shahrez
- alekazam
- rock_it
Umm.. With the LED's, they have to be around a certain way ... So, if none of them work, switch them around... It is all to do with how the negative is with the LED globe ...
- ft04me
yep i did this too... didnt work... i plugged in the leds to a battery to test if they are working and they are...rock_it wrote:Umm.. With the LED's, they have to be around a certain way ... So, if none of them work, switch them around... It is all to do with how the negative is with the LED globe ...
the dimmer is fine..checked that too...
its just the 5 lights that dont work..
even when i plugged in the original globes they dont light up as well and i've tried them too with a battery
- rock_it
Hmmm ... Well as the tree said to the lumber jack ... "I stumped" ...
- rock_it
I think there are fuses in the footwell, and under the hood ... But never looked for them...
Is the speedo sitting back in properly
It may not be sitting in, which could mean that the circut is not complete... Check the back of the speedo and make sure there is nothing bent... Has been a while since I looked at the back, but there should be to slots that plug in...
- Shahrez
- vipfto
- mr-charisma
If you look at your fuse boxes this is the translationft04me wrote:Does anyone know where I can get the fuse box translation?
Interior fusebox:
[10A Horn]....................[30A Defogger].......[15A Door lock]
[10A Heater Relay].........[nill]......................[10A TCL]
[15A Cigg Lighter]..........[10A Meter]............[10A Back door lamp]
[10A A/T].......................[15A Wiper]...........[10A turn signal lamp]
[10A Folding mirrors]......[nill].......................[nill]
[20A Sunroof]................[30A Heater]
Engine Bay fusebox:(3 banks on the right side)
[nill].......................[15A Stop lamp]............[nill]
[nill].......................[10A Hazard lamp].........[40A* Ignition]
[10A Tail lamp]........[15A Fog lamp]..............[30A* Radiator fan]
[10A High beam].....[nill]..............................[40A* Lamps]
[10A Air con]...........[30A Condensor fan]......[20A* MPI]
[10A Room lamp]....[30A* Power windows]....[100A** Alternator]
[15A Stereo]...........[50A* ABS]....................[60A* J/B]
* = Fusable link
**= 80A on mine but it has been blown before by the panelbeater, battery wouldnt hold its charge, scared the sh*t out of me
- mr-charisma
ft04me wrote:ok guys since im gonna be at work all day..
if its not the fuse then anyone else have any suggestions what it could be...
i've checked the fuse and im pretty sure non is blown..
Keep in mind the dash connections are hooked into a few other things, aircon display & other centre instruments, door lights, etc .. if you've been playing with any other wiring it could be related..then id be double checking you have the bulbs correct way again and get the multimeter out on the dash connections to see if your getting power
