Guys, my FTO been sitting in the front lawn for atleast 12 months. Fuel would have evaporated by now! I just flush and change coolant and did the oil and filter. Put in 10 litres of fresh fuel. and even gave it a kick start with "start the bastard". The "bastard" refuce to start. Sparks are working, as it combust using the "Start the bastard" straight in the air filter. But clearly the fuel is not feeding through.
Suggestion please.
ps, vehicle was running perfect before it decided to hibernate for the next 12 months.
FTO GPX Fuel not feeding car stagnent
- Saltiga
- zuihoujueding
- koolio1234
- Saltiga
You should not undo the fuel filter/lines with out first releasing the pressure.
Do this by removing either the fuel pump relay or disconnecting the fuel pump.
As for the bolt you need 2 spanners. One on the filter and one on the line, should come undone doing it this way
