climate control has a mind of its own
- Cassf88
if i start the car at 19 degrees n turn it up to 20.5 the air con sometimes turns on. after i switch the car off n start it up again the fan will speed up automatically n the bars that show the fan speed also start to appear until i interupt n press the down button... any ideas? it doesnt always happen but its not during hot or cold days or anything like that- just whenever
- FTEvolution
I have another question about that sensor...
What are the chances of re-routing it (and upgrading it of course) into the intake air stream? I mean, I really don't give a f**k what the outside temperature is
Could be useful to see what my intake air charge temp is
Smooth and sleepy
Smooth and sleepy
- koolio1234
Thats quite a good idea, I was thinking of setting a completely different one for my intake but thats even better. I guess you could just dismount the sensor from its present location and IF the wiring is long enough, re-route it to the airbox. Might actually serve a purpose then.FTEvolution wrote:I have another question about that sensor...
What are the chances of re-routing it (and upgrading it of course) into the intake air stream? I mean, I really don't give a f**k what the outside temperature is![]()
- jonowong
Re: climate control has a mind of its own
call the exorcist... there's a demonCassf88 wrote:if i start the car at 19 degrees n turn it up to 20.5 the air con sometimes turns on. after i switch the car off n start it up again the fan will speed up automatically n the bars that show the fan speed also start to appear until i interupt n press the down button... any ideas? it doesnt always happen but its not during hot or cold days or anything like that- just whenever
- howc
jonowong wrote:call the exorcist... there's a demonCassf88 wrote:if i start the car at 19 degrees n turn it up to 20.5 the air con sometimes turns on. after i switch the car off n start it up again the fan will speed up automatically n the bars that show the fan speed also start to appear until i interupt n press the down button... any ideas? it doesnt always happen but its not during hot or cold days or anything like that- just whenever
Yeah i have been thinking about this for a while but just another one of those projects i have no time for lol.FTEvolution wrote:I have another question about that sensor...
It would be extremely easy to do but i would also remove the factory temp sensor and get one from dicksmith (or the like) and it would be far more acurate
- FTEvolution
Yeah, there is no way the standard one would handle the intake temperature OR the intake pressure (I want it in the IC piping before the throttle body, but before the BOV too)[/b]I8A4RE wrote:Yeah i have been thinking about this for a while but just another one of those projects i have no time for lol.FTEvolution wrote:I have another question about that sensor...
Smooth and sleepy
Smooth and sleepy
- Robbie
- Robbie
When it does this does the temp automatically revert back to 25degrees? Or does it stay at the same temp as you had it on last?
Either way i think it is a faulty control module
