FTO stalling after 5 mins
- boulizos
I have a problem with my FTO. It is a 1996 GPX Mivec Auto (tip).
At first the car would start normally, run for 5-10 mins and then engine would then stall. The car would stall while we were driving. It would not restart immediately. After about 5-10 mins it would restart and drive perfectly for an unlimited time.
We had is serviced and changed the fuel filter. The car worked ok for about a week and then the problem returned. This time the engine light would come on before the car stalled. The mechanic tested the code and said it was the booster control, however we do not have a turbo. He reset the computer and cleaned the throttle body and the car was fine for a few days, but then the problem returned. The problem was sporadic. Some days it would run fine, other times it would stall and we would have to wait 5-10 mins before it would start properly.
This time we had an electrician look at the car. He said that our alternator was overcharging and we had it replaced. The car worked for one day and now the problem has returned and is even worse. It will start and stall straight away. It will do the same after several attempts. It will then start normally, drive for about 5 minutes and then stall again. It will not restart until after another 5 or 10 minutes.
Today we disconnected the battery to reset the computer. After reconnecting the battery the car started perfectly. We left it to idle for 5 minutes, as instructed by the mechanic. but it stalled after only a few minutes. Once again it wouldn't restart straight away.
Please help??
Please help??
- koolio1234
Im agreeing with ben, but i would definitly be checking error codes before i did anything.
- boulizos
Someone here might have a spare they can lend you if you just want to test the theory.boulizos wrote:Thanks for that, much appreciated. I was looking at getting a stepper motor but looking at others with the same problem and not seeing results, i wasnt sure.Bennoz wrote:Stepper (Idle control motor) is shot. Would wager my first born on it.
Ill give it go and let you know.
Kind Regards
yep i will if your close to me i got gr and gpx (not sure if there's a difference).
Where abouts you located?
mate thats what this club is for....helping each other out.
If none of the sydney guys can help you out then i can send you mine down to test if its the problem, you would have to pay for postage of course
- boulizos
thanks for your help, i would be interested if anyone would like to sell one as testing one may cost as much or take more time to organise as i am very limited with time.I8A4RE wrote:mate thats what this club is for....helping each other out.
i hope you all had a good easter, as i had a busy weekend as my cousin is marrying a rebel... and lucky i went home early that night as you have seen on the news that they made some trouble at star city casino.
But yeah if anyone has one i may purchase i would be geatful.
you can purchase 1 new for $195 delivered or dstocks may have a secondhand one.
They are really easy to replace you could do it yourself. i could do a DIY if needed
- boulizos
its kewl bananas, ill grab one from mcgraths. i couldnt find anywhere that delivers, that would be a lot easier. i seen a few sites on installation and it looks easy enough.I8A4RE wrote:you can purchase 1 new for $195 delivered or dstocks may have a secondhand one.
- boulizos
I let the car run for 5min's, then i went for a short ride and it died. the engine light came on and it shut down and would not start for 5mins. it then started and i drove for 1min and the gears became erratic, going from forth to third to second to third and then died. again waiting 5min and it drove for 1min and the same problem occurred.Bennoz wrote:Stepper (Idle control motor) is shot. Would wager my first born on it.
Could this be the computer itself ?
- boulizos
- boulizos
Haya, I did reset the ecu for over an hour, and it seems it hasent made any improvement. ill keep trying though. thanks for your helpBennoz wrote:Have you reset the ECU? Ie disconnect the battery for a half hour or more?
Also keep in mind, when you do this the car takes a good couple of hours of driving to 're-learn' where it is meant to idle. During this period the car will stall & f*ck around whilst it getting its sh*t together.
