After my servicing, i was told my air con belt has a crack and is worn... and my transmission has a minor oil leak.
Do you guys know anywhere that i could get the belt and how much it would cost all up?
How do you fix an oil leak? How much does it cost?
Air con belt cracked AND transmission oil leak
- ellusion
If I were you, I'd check that your Air Con compressor is working properly. If the compressor is on its way out, it could be the reason why the belt is cracked. Through previous experience, it is essential that you get it checked before it sh*ts itself. Having part of your car on fire is not a good thing!!
