GR belts
Jamie
GR belts
Post by Jamie »
Can someone tell me please if I have the part numbers for the 2 belts right to suit a 97 GR.
MD184973 Alternator belt
MD321692 P/S, A/C
Not sure man but if you get me the gates equivalant numbers i can get some good prices for you
Belts are generic, get 'em from any auto shop.
4PK940 and 6PK1080 are your generic belt part numbers.
Jamie
Post by Jamie »
@ bennoz thanks for the correction on the numbers.
@ I8A4RE thanks for the offer. I will look tomorrow for the equivalant part numbers. Are the gates belts better quality than the generic ones?
Also stupid question but where is the water pump located on the GR? Dont remember seeing a pulley for it :?
Water Pump is located under the timing covers. It is run off the timing belt.
Gates are just as good if not better than OEM. We use gates here on all our machines and if one failed it would cost us tens of thousands of dollars. They run everyday all day..... So yeah very reliable.
