Hey guys, just wondering where would i be able to find one? cause i need one asap due to mine has 2 leaks in it. And how much would it cost around or a recon or new?
thanks heaps
Gpx manual gearbox
- eddiii
- bushido
work out where the leaks are coming from first or have you already done this?
failing this, check out ebay or start calling wreckers. Wreckers will be very hard as when I was looking for a manual driveshaft, out of all the 20 places I called, noone had one hehehe. All autos
- bushido
shaft too short? you might have the incorrect dirveshafts both sides. that could cause the two leaks. if yours is a mivec manual then look up the part numbers and see if you can get it from a wreckers.
